Sponsored by:
Sponsored by: Kumho
Master cylinder?
Old Oct 21, 2011 | 04:44 PM
blueis300's Avatar
Default Master cylinder?
Just signed up to help father in law. He has a 2003 f150 with the 5.4. His brakes get spongy sometimes. He has seen some fluid at the back of the cylinder and booster but not much or all the time. Ive read alot of posts and it could be a number of things. His fluid is dirty and he bleed the brakes months ago. That could point to the cap. Im just reaching for stuff from what I have read but hoping someone with more knowledge could help.
Old Oct 22, 2011 | 07:47 AM
You should NOT see any fluid on the back of the master cylinder (NEEDS TO BE REPLACED)
Dirty fluid. Can also cause the peddle to be spongy. moisture in the fluid. (BRAKE SYSTEM NEEDS TO BE FLUSHED)
Welcome to the forum
Old May 25, 2021 | 01:06 AM
Chuck2500's Avatar
Default Brake booster should be checked.
Sponge like pedal if bled rite is the booster.check your pistons and wheel cylinders for leaks first.and for sure swap out old brake fluid.
cubpak89
Jul 15, 2011 09:59 PM
BIZZLE
May 19, 2011 07:47 AM
Worf
Dodge/ Ram How-To's and Tutorials
Feb 22, 2011 07:33 AM
Worf
GM How-To's and Tutorials
Apr 13, 2010 06:05 AM
Worf
Ford How-To's and Tutorials
Apr 1, 2010 02:50 AM
