Ford General Tech Ford tech talk within.
1991 ford f 250 low idle surge and stall
Old Sep 7, 2013 | 11:06 PM
ford tuff's Avatar
Default 1991 ford f 250 low idle surge and stall
HI I am new to this forum but thought I would give it a try I have a 1991 ford f 250 with 302 50.L it will run fine at a 1000 rpm but when it drops under that it will start to surge and then stall I checked the ICA and cleaned it and Know that it working properly I have not done a sweep test on the TPS yet I also know that my fuel press is within spec. what I was wondering is if my sweep test checks out ok is where do I go next if I had a leaking intake gasket would that create the same symptoms or if I had bad grounds could that cause the same thing
ofg
Mar 27, 2012 06:53 AM
bandit79mpr
11
May 4, 2009 11:29 AM
MrLM7
Feb 16, 2008 11:10 PM
silverado_ia
Jun 14, 2007 11:02 PM
mrhaney
Vehicles for Sale
Aug 10, 2006 12:01 PM
