2005 f250 5.4L v8 crewcab 4x4
Old Apr 4, 2012 | 05:27 PM
Phil Schwenger's Avatar
Default 2005 f250 5.4L v8 crewcab 4x4
Trucks very sluggish when i begin to hit the gas. anfter a few seconds it begins to smooth out. Sometimes my check engine light will flast off and on also. any ideas? Bad coil pack? plugs? mass airflow? its shifts gears fine.
Old Apr 5, 2012 | 08:08 AM
Dan the man's Avatar
i would start with changing the fuel filter and run a additive to clean it out see if that changes it and clean the mass air censer , if that does not work maybe start with those other items
Old May 2, 2012 | 10:43 AM
Sideburns's Avatar
Start with what Dan said. If that don't fix it, check your other items in addition to the cat. A blocked cat will rob you of power therefore making it sluggish. If it's causing to much back-pressure then it can throw a code sometimes. I've replaced the cat, plugs, and coils on my truck and those made all the difference on my 2000 5.4
basswall
Jul 2, 2012 12:10 PM
basswall
Apr 24, 2011 04:23 PM
basswall
Feb 20, 2011 02:40 AM
obspec
Jan 23, 2008 01:15 PM
gregt909
Vehicles for Sale
Jan 9, 2008 03:36 PM
