2011 F-250 Trailer Turn Signals
Took the boat out last weekend and found out on the way home that the trailer lights were not working on the factory installed towing system (4-pin/7-pin combination).
Ive done some digging and replaced a fuse under the hood and got my running lights back on the 4-pin socket but still have no turn signals/brake lights, and NOTHING on the 7-pin. Weve recently moved and my Owners Manual apparently found its way into a box that hasnt been unpacked so I have no way of knowing which fuse/breaker/relay Im looking for. Ive checked all the fuses under the glove box, all are good. The ones under the hood APPEAR to be good but some are hard to tell if the wire is intact or not. No way to test them short of pulling them and popping the cap off (the low-profile box type fuses), not an idea Im particularly fond of not knowing exactly which ones to start with. I googled for fuse diagrams but the results brought up diagrams that showed trailer light fuses in locations that never had a fuse to start with. Anybody got a book that can share some reliable fuse/relay locations or where else I need to be looking? |
If you go to Welcome to Ford Owner | Official Ford Owner Site
you should be able to download or read on-line the owner's manual for your truck. |
Originally Posted by Legendsk
(Post 84075)
| All times are GMT -5. The time now is 08:46 AM. |
