-   -   99 F250 - valve problem - 5.4 V8 Triton (https://www.truckforums.com/forum/ford-heavy-duty-101/99-f250-valve-problem-5-4-v8-triton-13663/)
johnh May 5, 2010 08:53 AM
I have this truck & doesn't idle very well. Guy before me told me it had a compression test & a valve was damaged. Want to do my own test. No signs of plugs or wires. Are they under the valve cover ? Can I tell the bad valve - int or exh - in comp test ? How to set valves after if I remove head to replace valve ? Thanks
Worf May 5, 2010 05:01 PM
you have to pull off each coil to find the spark plugs. The plugs sit under the coils. A service manual will show you how to set the valves if you need to replace them.
johnh May 6, 2010 08:55 AM
Yes, is there a link that would have a FREE download or someyhing to even look at even just to copy down with a pencil - as far as doing a valve set on this 5.4L Triton >>>>> Thank You.
