brake issues??
Old Feb 1, 2015 | 08:01 PM
mo_goblins's Avatar
Default brake issues??
New to the forum any help is appreciated. Have a 2004 2 valve 5.4lt f350 xl 4x4 that's suffering catastrophic brake failure. Is there any diagrams on the brake line layout? Brake pedal is really soft. Fluid reservoir stays full.... bled the system to no prevail. Followed the brake lines and it lead me to the rear axel splitter that transfers it to each rear tire... I found a line in, two lines out (one to each tire) then one that leads up to the frame that just suddenly ends. Is this normal? Iv tried to find the place it's possibly supposed to run to but couldnt locate it.
Old Feb 1, 2015 | 09:18 PM
This line you say that goes no where is part of your rear ABS system. It belongs under the truck box.
Did you figure out why you lost your brakes?
Did you have to top up your brake fluid from the fluid loose?
Old Feb 2, 2015 | 10:16 AM
mo_goblins's Avatar
Thanks lots of help... the line I described isn't attached to anything comes off the axel for about 1.5 feet has a v fitting then just ends.. I knew it had to be connected to something but couldn't find the receiving end.
Old Feb 3, 2015 | 02:24 PM
mo_goblins's Avatar
Do you know where abouts the rear abs module is located in the frame? I have looked but cannot seem to locate it. I's it between the frame and gas tank?
gerktj
Jul 30, 2011 03:43 PM
moto one
Silverado/Sierra FAQs
Jul 24, 2011 11:13 AM
tomtsled
Dec 18, 2010 10:32 AM
greme
Jan 16, 2006 02:25 AM
skymangs
Oct 17, 2005 04:43 AM
