F-250 SD Headlight/headlamp
I have a LS headlight, that must be cracked somewhere, as it has some [ 1/4in] water in the bottom. Lamp still works,, has for some time this way. You can see a 'chip' dead center but you cannot fell it,, must have blew the chip off inside,,,, ??? no matter,,, lamp has water in it and lense is cloudy with moisture.
My light says SEALED BEAM on the top of lense. I did a search for F250 headlight,, all I see is the H-light assembly,,, that takes the bulb,,, some are as much as 200 bucks a pair,,,,,,?????????????
Can I just go to AutoZone, Reiley's or Napa,, and ask for a sealed beam for an 2002 F250 SD ????
The manual also shows 2 headlights that were installed on the 02 F250,,, Sealed beam,,,, and the bulb type,,,, was that an option or a mid season mfg change ?
ProRider199
May 15, 2006 09:17 PM
