Horn and cruise control
Old Oct 11, 2012 | 06:46 PM
Robert Del Valle's Avatar
Default Horn and cruise control
I lost my cruise control and horn all at the same time. any idea why, and or how to fix it?
any advice is greatly apreciated
Old Oct 27, 2012 | 12:01 PM
vman's Avatar
ck your speed control servo under the hood. ck connetor for brake fluid if it has fluid,you need to replace deactivation switch on master cylinder. the horn uses the servo as ground. hope this helps
Old Oct 29, 2012 | 12:53 AM
RustyFordLover's Avatar
The horn and cruise control I believe use the same relay ground, so if one relay is out, the other one wont work, and i also thing they are hooked into the same fuse in the fuse box.
Mrjeff62
Oct 9, 2014 11:48 AM
beentattooed
35
Aug 17, 2011 01:55 AM
lkamp6969
Nov 25, 2010 11:03 AM
isaac_22
Dec 24, 2007 12:33 PM
JAK
Oct 27, 2006 07:24 AM
