Spongy Brakes
Old Apr 29, 2013 | 06:04 PM
ImTrouble's Avatar
Default Spongy Brakes
When I push down the brake pedal as far as it will go w/o using excessive force, the truck stops, but then the brake pedal will slowly start to begin going lower and lower. I have to pump the break to get the pedal back to where it feel like I pressing on the break.
What does this mean, and how do you fix it?
Thanks
Old Apr 30, 2013 | 09:41 PM
Sounds like you've got a brake fluid leak.
Old May 2, 2013 | 06:46 AM
gmcmannow's Avatar
Thanks
Usually means your master cylinder is going
Old May 2, 2013 | 12:09 PM
smallblockfox's Avatar
yup. . i have the same issue in mt 1988 ford f350 right now. just a case of a worn out master cylinder. super easy to fix. two bolts and two lines. slip on the new one and done
tached93gt
Oct 3, 2007 08:37 AM
makoltd
Nov 2, 2006 04:31 AM
vsilz
Oct 20, 2006 10:39 PM
silverado05
Jul 23, 2006 06:35 PM
Spufi
Nov 27, 2005 09:14 PM
