1996 5.7 V-8 fuel system problem
Old May 20, 2007 | 10:47 PM
speedo45's Avatar
Default 1996 5.7 V-8 fuel system problem
I have a 5.7 that has the centralized sequential injector system and something is wrong. When I turn the key to start, the system "floods" #3 & #5 with fuel, so much that I had to drain the oil(it dumped over two qts of gas into the pan). What would be the problem and what should I attempt first to fix the problem?
Old May 21, 2007 | 05:38 AM
Argon's Avatar
Default RE: 1996 5.7 V-8 fuel system problem
Any codes??..You say 3&5,which is on the drivers' side...Most of those pressure regs leak eventually,but on the other side
Old May 21, 2007 | 06:25 AM
speedo45's Avatar
Already replaced the pressure regulator prior to the problem and drove over 100 miles . No codes pulled yet.
Old May 21, 2007 | 10:26 AM
Argon's Avatar
Then you either have..
Faulty injectors...
A grounded wire somewhere causing the flood
A bad pcm
I have no clue of your technical ability/tools...but this will be a crapshoot without some real diagnosis....
jrk99
Dec 7, 2009 11:57 PM
southernjames06
May 9, 2008 10:15 AM
rancho1024
Jan 4, 2008 09:43 AM
tas2826
9
Aug 24, 2007 06:08 PM
speedo45
May 20, 2007 11:02 PM
