5.7L Vortec issue
Old Apr 3, 2010 | 12:13 PM
1997Silverado's Avatar
Default 5.7L Vortec issue
I have a 1997 Silverado, with a 5.7L Vortec and recently the engine has started to stumble and hesitate during acceleration and heavy load. I have recently replaced spark plugs, cap and rotor and fuel filter and haven't seen any improvment. Any suggestions?
Old Apr 3, 2010 | 12:55 PM
I would check the fuel pressure. Those also have a spider type fuel injection that is known to go bad. Is it hard to start?
Old Apr 3, 2010 | 02:15 PM
It starts and idles fine.
Old Apr 3, 2010 | 02:41 PM
The check engine light is not appearing and I didn't find any codes when i scanned.
Old Apr 3, 2010 | 06:40 PM
A weak fuel pump would not necessarily trigger a CEL. The spider injection could be causing that. I have had to replace a few. Also you did not list plug wires...a bad wire could cause that as well. I would still do a fuel pressure test though.
Old Apr 7, 2010 | 07:48 PM
GMC1989's Avatar
you also could have a vacuum leak at the intake gaskets or a bad vacuum line.
Old Apr 8, 2010 | 02:33 AM
Worf's Avatar
I agree with mr. shamrock sounds like a fuel problem. It is possible that it is the fuel pump.
Old May 1, 2010 | 11:55 AM
Recently I have started to get the check engine appear under heavy acceleration. I scanned it and it shows that I am getting low voltage readings on both pre-converter 02 sensors.
FREAKZILLA
Feb 21, 2011 02:03 PM
jaxontipedeau
GM How-To's and Tutorials
Jan 31, 2011 04:17 PM
Prosto
May 23, 2006 02:47 PM
98ChevyLuv
Jan 16, 2006 10:16 PM
klrjoe
Dec 7, 2005 05:32 PM
