'93 1500 Steering Column
Old Oct 25, 2007 | 04:16 PM
RickMay's Avatar
Default '93 1500 Steering Column
Hello,
I have a 1993 Chevy 1500 Z71 Short Bed Pickup. Within the past couple of years, I've had to had the steering column replaced two or three times as it keeps coming loose after a while. Any idea what could be causing this? A mechanic told me that pulling yourself up into the truck will cause this (this, of course, is obvious), however, that really hasn't been an issue as I'm always conscious of this when I get in and out of my truck. Is there a possible mechanical problem or is this caused simply by a bad personal habit I'm unaware of? Thanks in advance.
Rick
Old Oct 25, 2007 | 09:03 PM
Argon's Avatar
Default RE: '93 1500 Steering Column
pulling on the wheel,yes.
its a chore..but you should be able to get it tightened up for about 2 hrs later....and tell em to loctite the bolts
davbell22602
Nov 12, 2009 08:30 AM
Jamci
37
May 13, 2009 08:54 AM
turbohvn
Apr 3, 2009 03:32 PM
Jimmy Lee
Mar 13, 2009 10:46 AM
albram
Feb 27, 2008 06:29 PM
