CHANGE A DUALLY TO SINGLE WHEEL!?!?
Old Oct 25, 2006 | 02:44 PM
amart100's Avatar
Default CHANGE A DUALLY TO SINGLE WHEEL!?!?
iS IT POSSIBLE TO CHANGE A CHEVY 87 DUALLY TO A SINGLE WHEELSET-UP? A LINK MIGHT POSSIBLY HELP ME OUT SO I CAN SEE IT DONE.. ALSO IF i WERE TO DO THIS WOULD THE TRUCK TAKE A LONG BED (8') OR A SHORT BED?(ARE ALL DUALLY'S LONG BED?- OR DOES IT DEPEND ON THE TRUCK) -THANKS
Old Nov 26, 2006 | 02:36 AM
bigblocks's Avatar
Default RE: CHANGE A DUALLY TO SINGLE WHEEL!?!?
If the front rotor has a hub adaptor on it just unbolt it it should have the same 8 lug pattern. the back should be a wheel swap. If you don't have ABS you might be careful of rear lock-up when empty or light loads due to less tire contact and a bigger brake.
derrin410
Jan 9, 2015 10:57 PM
trev0006
Feb 22, 2013 08:16 PM
stusharp84
Feb 18, 2012 12:53 PM
Robbs10ext
Apr 23, 2008 03:25 AM
blazer79
May 29, 2007 01:02 PM
