engine noise
i have a 2002 gmc 1500hd with a 6.0. it has 250,000 kms on it but there is a slight tick in the engine sometimes. i was wondering if it could be lifters or rocker arm tip. its a big job to change lifters so i was wondering if anyone else has had this problem.
does it only do it on start up if so its the common piston slap that gm says is an ok thing and wont hurt nothing
but it also could be a sticky lifter or sticky valve
also could possibly be a small exsausht leak if its small enaugh it will tick like that and its anoyying
If it is for operating temperatures, are staying in cold place, then till the engine heats up ticking noise will remain. If it is so then it is an engine bearing damage.
I agree with you, the problem in the engine is because of damage caused in engine bearing
05 chevy 2500hd
Apr 3, 2011 11:50 PM
98silverEDK
Aug 24, 2007 07:53 AM
brian46205
Jul 10, 2007 08:34 AM
