Engine won't take fuel
Old May 10, 2015 | 01:59 AM
scooterman's Avatar
Default Engine won't take fuel
I have a 1986 5.0 that starts fine, but idles rough. I can drive her, but if I stomp the gas she will die. Acceleration is poor ( have to go easy on the pedal or she will bog down ) and mileage is horrible. Gave tune up, changed cap, plugs, wires; no difference. No cat converter, running cherry bombs. Can't find any vacuum issues. Totally lost at this point. HALP! Please!
Old May 10, 2015 | 07:33 AM
It must be a bad vacuum leak somewhere or needs cleaning? or bad intake or carb gasket.
Old May 10, 2015 | 11:54 AM
scooterman's Avatar
When I bought the truck and experienced the fuel problem I found the carburetor was loose on the manifold :/. Gasket was fine and I tightened it down. Cleaned the carburetor but no improvement. Will start following vacuum lines. Thanks for the advice, gave me a direction to follow!
Old May 11, 2015 | 06:56 PM
Have you cleaned out the carbuerator? It's definitely worth getting that completely gone through. It almost sounds like a stuck float needle
Old May 12, 2015 | 10:09 AM
scooterman's Avatar
Found a leaking vac line. Got the 4 barrel to kick in for the first time, but still coughs and sputters. Starts right up and idles fine, but I think a carb rebuild is needed. Am going to drive it a bit and hope for improvement. Hope springs eternal!
Old May 22, 2015 | 04:06 PM
scooterman's Avatar
Taking the carb off, boiling it out and rebuilding it. $30 rebuild kit has everything and more. Taking over the kitchen table for a while
Old May 22, 2015 | 09:07 PM
If this works, you better take your girl out for a nice night out. I mean your wife, not the truck.
Gloveberg
Dec 21, 2010 09:35 AM
ford4ever
Ford Concepts & Rumors
Oct 3, 2007 08:49 AM
2000_z71
Aug 12, 2006 11:40 PM
GMCSierraVortecHP2K5
May 26, 2006 02:04 AM
santeejohn
May 13, 2006 05:29 AM
