steering troubles
Sorry to bother you guys with my problems but I have a issue with my steering. When I hit the gas pedal too much and the rear end breaks traction my steering goes off alignment 10 degrees and will not correct itself untilI have turned a few corners. I have had a frontend inspection, evo sensor replacement,4 wheel alignment, rearend inspection all of which have not solved the problems.
Any help is greatly appreciated.
Thanks,
Tony
p.s. 1999 tahoe, 4x4,lt package, 185,000km
Thanks,
Tony
With that kind of miles on the truck you probably have a steering box thats getting pretty worn out. If the whole front is tight thats what i would change cause nothing else can change where your steering wheel sits.
