Shifting Troubles
Old May 1, 2006 | 07:29 PM
Hlgreear@gmail.com's Avatar
Default Shifting Troubles
Hi Everyone,
I am having issues and I am at quiet a loss as to what the problem could be. This is my first truck and these are all new problems for me. The truck had a new clutch put in it before I got it so I am hoping it is not the problem. Yesterday, it was driving fine and suddenly it became very hard to shift. Its hard to place it in any gear. I have to two hand pull on the stick to get it into first gear and sometimes I have to turn the truck off and put in first then start and go. I have messed around with the zbar linkage, the one that has a long nut and bolt and I can not turn the nut out any further. Is there something in particular that would cause such a random problem? There is plenty of tranny grease. Is this a problem caused by a pressure plate? Additionally, if it is of any relevance, if I engage the clutch and hold it and get the truck in reverse, the truck will move backwards despite the fact the clutch is engaged. This has never happened before. Any help would be greatly appreciated.
-Howard
[IMG]local://upfiles/1436/8FE1A63632D641AD96BDC72C4D04E903.jpg[/IMG]
Old May 2, 2006 | 01:57 PM
RedChevy99's Avatar
Default RE: Shifting Troubles
i think i can help you locate the problem. i think it is the pressure plate. i work at a service station, and a guy had came in with the same problems after installing his own clutch. basically the pressure plate was causing the hard shifts. hope this helps, if not sorry.
Old May 4, 2006 | 07:10 PM
Hi, Thanks for the reply. Yeah I am getting ready to tear into it today or tomorrow. When I pull the pressure plate out, how can I test it to see if it is bad? Will i know by seeing it? Thanks for any help.
-Howard
07ram4.7
Feb 1, 2008 12:46 AM
S15WitDa4three
Jul 25, 2007 11:54 PM
cory767
Jul 3, 2007 11:08 PM
notamechanic
May 27, 2007 09:52 PM
dansZ71
Apr 12, 2007 06:02 PM
