Stuck in neutral
Old Mar 23, 2009 | 08:03 PM
1low87c10's Avatar
Default Stuck in neutral
I hope someone has a clue. I have an 87 Chevy C10 with the Muncie M20 transmition. It's stuck in neutral. Anyone out there have an idea how to get the shifter to move again? There doesn't seem to be any external linkage; the shifter enters straight into the tranny.
Thanx!
Old Mar 24, 2009 | 08:24 AM
evidica's Avatar
first thing I would check is that your stop light sensor is working. They are usually attached to your break pedal and determines when you depress your pedal which allows you to switch gears.
Old Mar 25, 2009 | 07:06 AM
1low87c10's Avatar
Default Stop light sensor?
That wouldn't be it. This is a manual transmission truck. You have to be able to shift without the brake depressed. Thanx for the input though!
jax-n-doz
Nov 2, 2010 02:37 PM
94GMC45
Nov 26, 2009 08:11 AM
john143
Sep 29, 2009 03:21 PM
RYDOG626
Apr 11, 2009 03:34 PM
Nocturnia
Mar 23, 2005 09:47 PM
