Truck hesitates and backfires
Old Jan 21, 2008 | 12:31 PM
jake1251's Avatar
Default Truck hesitates and backfires
I recently purchased a 1990 Chev.Truck with the V-6 engine. The truck has always started and has always idled a little rough but ran decent. Just recently it has gotten worse. It still starts and idles a little rough but when you push down on the gas it hesitates and if you push down real hard it backfires. It acts like it is starving for gas. I recently replaced the fuel filter and the old one looked as though it was original and was somewhat plugged compared to the new fuel filter, but no difference. I'm now thinking its the Idle air control valve. Is this IAC located on the side of throttle body and does it have a 3 pin connection, if not what is this 3 pin electrical connection on the side of the Throttle body?When I take this connection off while engine is running the engine sometimes, not always dies. What would suddenly make the engine start too hesitate and backfire.
Old Jan 21, 2008 | 01:01 PM
stopspazinout's Avatar
Default RE: Truck hesitates and backfires
the iac is beside that one it has a 4 pin sqaure connector that 3 pin should be your tps.
Old Jan 22, 2008 | 11:09 AM
slc10844's Avatar
When was the last time it had a good old fashioned tune-up? Compression check, plugs, wires, cap, rotor, etc.
gomer snerd
Mar 11, 2011 05:36 PM
jmh080630
Jun 30, 2010 11:04 AM
imakedirtlookgood21
May 21, 2008 05:12 PM
imakedirtlookgood21
19
Apr 13, 2008 04:39 PM
imakedirtlookgood21
Apr 6, 2008 04:22 PM
