95 k1500 accelerate troubles
Old Aug 29, 2021 | 09:36 PM
Coreysmobilemechanic1's Avatar
Default 95 k1500 accelerate troubles
Ive been fighting this truck with my life it cranks up runs but on acceleration it cuts out on me and dies new iac coil pack plugs wires injectors distributor cap and rotar tineing is to the t any help would greatly be apreciateappreciated
Old Sep 16, 2025 | 09:05 AM
NioMarvin83's Avatar
Check the fuel pump and fuel filter. A weak pump or clogged filter can cause cut out when you press the gas. Also check the mass air flow sensor and vacuum leaks. Make sure the ground wires are clean and tight. A scan tool can show if a sensor is giving bad data.
sofasurfer
May 3, 2010 03:37 PM
sovablunt77
Nov 25, 2008 09:51 AM
motoracer11
Aug 20, 2008 10:23 PM
motoracer11
Aug 20, 2008 01:00 PM
Willy
Sep 1, 2007 09:46 AM
