Best EGR Delete Kit Recommendations?
Old Apr 28, 2025 | 07:36 PM
fsxbob's Avatar
Default Best EGR Delete Kit Recommendations?
Hello everyone.
I'm planning to delete the EGR on my truck and could use some advice before I start. I've seen a lot of options online, but I'm not sure which ones are truly reliable. I’m especially focused on finding an egr delete kit that’s durable, easy to install, and doesn’t cause any unexpected engine codes. Some brands get a lot of praise, while others seem to cause more problems than they solve. If you’ve installed an EGR delete, which kit did you choose, and would you recommend it?
Any tips or lessons learned during your install would be appreciated!
Old Jun 12, 2025 | 08:12 AM
NioMarvin83's Avatar
I did an EGR delete on my truck. I used a kit from Flo\~Pro. It fit well and came with clear parts. I had no problems with engine codes because I used a tuner to turn off the EGR system.
Some people also use kits from Sinister or Pusher. Make sure the kit matches your engine year and model.
Tip: take your time, follow each step, and double-check all clamps and hoses. Have extra coolant ready too.
If your truck is still under warranty or you need to pass emissions, check the rules in your area first.
gordiejohnstone
Sep 22, 2024 11:47 AM
mrvideosawyer
Oct 9, 2013 08:30 AM
superdutyaaron
Aug 27, 2010 03:32 AM
pear69
Feb 7, 2009 05:30 PM
gas guzzlin 4x4
Apr 6, 2007 11:20 PM
