can not fill tank
Old Nov 18, 2024 | 07:54 AM
txgambler's Avatar
Default can not fill tank
I have a 08 avalanche that I can not fill with gas . No check engine lights or stored codes .Fill tube has been removed and nothing found in tube .Evap charcoal canister has been replace because that's what I thought was issue (no fix ).Replaced solenoid valve even though I can blow air with no restrictions ( no fix ). All I can find is everyone keep saying vent lines and evap system . I am trying to find out where the fill tube connects to tank is there a check valve . I ask this because when I removed the fill tube off t the tank it has a moving piece inside that I can move around with my finger but I can not push it open and thinking this is some kind of spring load inlet to tank that is broke and not opening to let fuel in ,
Old Nov 19, 2024 | 12:28 PM
txgambler's Avatar
anyone ?
Old Nov 23, 2024 | 12:36 PM
txgambler's Avatar
Hello??
the sac
Sep 30, 2012 12:16 PM
FxrUpr2005
8
Jan 27, 2012 10:29 AM
jeffmc
Mar 21, 2010 05:51 PM
RedtoBlackZ71
May 28, 2009 12:22 PM
dmbaero
Mar 12, 2009 12:51 PM
