Disassemble Radiator of Isuzu 4JJ1 Engine Truck
Old Mar 20, 2023 | 04:24 AM
Oswin's Avatar
Default Disassemble Radiator of Isuzu 4JJ1 Engine Truck
Removal
1.Loosen the water drain plug(on the rear right side of the engine) and radiator drain plug, and completely drain the coolant.
2.After completely draining the coolant, securely tighten the drain plug.
3.Remove the intake hose, turbocharger side, intercooler side, and intake pipe bracket between the turbocharger and intercooler.
4.Disconnect the ECM harness connector.
5.Remove the boost sensor harness connector(1).
6.Remove the intake hose, throttle side, intercooler side, and intake duct bracket between the intercooler and throttle valve.
7.Remove the radiator upper hose at the radiator side.
8.Remove the radiator lower hose at the radiator side.
9.Remove the fan guide bracket.
10.Remove the ATF coolant pipe from the radiator.
(Smoother vehicles only)
11.Remove the radiator.
a.Remove the intercooler from the radiator.
b.Remove it carefully from between the left and right frames, ensuring that the radiator and fan blade do not touch and get damaged.
If you have any other questions, Email: Sales@obd2.ltd
timber74wolf
Jun 10, 2023 08:49 AM
caantunez
Jun 21, 2012 05:58 AM
cubpak89
8
Aug 6, 2011 01:06 PM
adampgasser
Feb 25, 2008 06:11 PM
bpa1216
Jul 23, 2007 05:04 AM
