Engine Break (Jake Break)
Old Mar 4, 2012 | 02:49 PM
dragonfly's Avatar
Default Engine Break (Jake Break)
New guy to the Forum.
I'm a DYI guy and would like to build an engine break for my '69 Chey C20 with a Perkins straight 6 354 ci. mated to a Fuller 10 speed manual trans. Any plans, list of components, info would be appreciated or a used unit.
Old Apr 1, 2012 | 07:36 PM
Diesel Dan's Avatar
To clarify you are going to need an exhaust brake not a compression release brake--aka "Jake".
Best I can say is google Diesel exhaust brake and contact some of the manufacturers/dealers and work with one of them. This will be a custom install.
Is your Perkins a turbo or n/a model?
Old Apr 2, 2012 | 12:52 PM
Ice_at_heart's Avatar
Just downshift, you're in a manual already....
Old Apr 2, 2012 | 02:06 PM
dragonfly's Avatar
An exhaust break is what I'm looking to build. I've seen several examples of manufactured item. Still looking for plans or parts. Making a unit isn't going to be difficult, but I'd like to avoid the trial and error mode. The main reason for installing the break is to take the pressure off the truck breaks descend the long grades. I will be pulling a 34' fifth wheel, 10K lbs. and truck wt. at 7K. Going down a 6% grade is no place to downshift, IMHO. Thanks everyone for the input.
Old Apr 2, 2012 | 10:37 PM
Diesel Dan's Avatar
Does it have a turbo?
If so try and match up the outlet to one from a 5.9L Cummins. Basically the same displacement. If it is not a turbo get turbo from a '89-91 CTD that was non-intercooled. You might have to step up the exhaust spring rate for heavy exhaust brake use, that was an issue on the 12V CTD.
How 'bout some pics of the swap?
Old Apr 3, 2012 | 11:51 AM
dragonfly's Avatar
Thanks for the info. Yes, it does have a turbo. I'm computer challenged about Photobucket, but will try to get some photo posted.
Old Aug 8, 2012 | 01:39 PM
dragonfly's Avatar
My first attempt at posting pics. Pictures by dragonflypro - Photobucket
Purchased a used PacBreake exhaust break that came off a FreightLiner. Reducer pipes, electri to vac solenoids also ordered.
Old Aug 9, 2012 | 08:07 AM
Diesel Dan's Avatar
Did a good job on the pictures.
Nice work on the project truck too. Belts look nice and straight, pyro in good location. What did the intercooler come from?
Limiting factor on a Perkins appears to be the lack of a cross flow head.
Keep up the good work!
Old Aug 11, 2012 | 01:16 AM
dragonfly's Avatar
It is a custom built intercooler.
dimmuborgir6nik6
Jun 8, 2010 05:06 AM
brotherblood
May 4, 2008 12:16 PM
wheredoesthisgo
9
Oct 5, 2007 11:12 AM
superddd
11
Sep 18, 2007 04:23 AM
greasepain37
Sep 14, 2007 06:38 PM
