Nissan Titan Discuss the Nissan here
Blinkers not working...Interesting Problem
Old Feb 6, 2009 | 07:34 AM
neal345's Avatar
Default Blinkers not working...Interesting Problem
When I go to use the blinker (left or right) the indicator light will blink once and then stop working. The interesting thing is that both blinkers will illuminate oncelike I was using the flashers. Has anyone encountered a similar problem? I did not check to see if the flashers are working but I plan on doing so some time after work.
Old Sep 18, 2024 | 08:28 AM
NioMarvin83's Avatar
It sounds like there might be a problem with the turn signal switch or the wiring. When both blinkers light up, it could mean there’s a short or a loose connection somewhere. You can try these steps:
Check the fuses – Look at the fuse box to see if any of the fuses for the blinkers are blown.
Test the flashers – Turn on the hazard lights (flashers) and see if they work normally. If they do, the problem might be with the turn signal switch.
Check the bulbs – Make sure the bulbs for the blinkers are working. Sometimes a bad bulb can cause strange behavior.
If you can’t figure it out, a mechanic can help check the wiring and switch.
82gmc1500
Jun 14, 2016 11:07 AM
ctucker
Nov 29, 2013 09:45 PM
Zabman14u
Jan 4, 2011 08:19 PM
lear_eric
Jan 31, 2010 06:44 AM
jimang22
Jan 2, 2008 10:06 PM
