Nissan Titan Discuss the Nissan here
Work truck running bad please help
Old Aug 13, 2007 | 09:29 PM
moondog99's Avatar
Default Work truck running bad please help
I have a 1992 Nissian pickup 4 cyl that idles high at 2000 rpm then drops to around 600 and back up again. This happens every 2 seconds. Also at any speed the truck shudders like it had a dead miss or like it is running out of fuel but it does not do it in a set pattern. What could it be? vacume leak?
Old Aug 14, 2007 | 06:00 AM
moondog99's Avatar
Default RE: Work truck running bad please help
This morning I checked for vacume leak using soapy water could not find any. also pulled the PCV valve and it rattles and is functioning properly, also checked the EGR valve and it is also ok. Any other ideas?
Old Aug 14, 2007 | 07:51 AM
Argon's Avatar
vacuum leak is always a possibility....(internal vacuum leaks are TUFFFF to find)..
But I'd bet on a faulty MAP sensor or Idle valve...sounds like she needs to be scanned
JJ CHEVY
Jan 31, 2012 08:26 PM
zleehw
Mar 9, 2010 12:28 PM
Cs361
Dec 8, 2009 04:17 AM
matto210
Apr 27, 2009 02:44 PM
partsguy
Sep 25, 2005 05:58 AM
