what else can i do 2 my chevy with out supercharge
i got a intake exhaust and a programmer hypertech and by way i like my warranty so i dont wanna get rid of it 2004 chevy silverado 5.3 373 gears regular cab i was wondering what else could i do 2 get more our of it with out puting a charger in it i mite add i run a 15.2 15.3 in a quarter mile and a 10 flat in 8th mile but i wanna break a 14.9 so if any 1 could help me thanxs a bunch
RE: what else can i do 2 my chevy with out supercharge
do you live somewhere that will permit headers or true dual exhaust? perhaps a high flow cat?
throttle body bypass. throttle body spacer
throttle body bypass...granatelli mass air flow sensor (new, not used)...low ohm plug wires...and one mo
re question... what is your terminal gear and rpm in the quarter? If you are maximizing your rpm range and power, you should go through the traps in third gear, at around 5300 rpm. I'll bet you may not even be getting out of second. If not, a shorter rear tire set will give you a net lower gear. For example, a 255/65/16 or 235/70/16 are both about 1.4 inches shorter than a stock 245/75/16. This would change the theoretic rear ratio from 3.73 to around 4.1, I believe. It might be worth a try. Finally, if you have upsized your tires, as many people do, going to a shorter-than-stock tire could make a real difference in your launch, and terminal rpm. jim |
I agree with the other guys, throttle body bypass, MAF sensor, headers, 3" cat back... The only things I would add would be to descreen the MAF (stock and or Granatelli) a good cold air intake I have had great luck with K&N, and get your PCM custom tuned, I know you already have the Hypertech but this will give you much more noticable gains and will be written for the mods you have and what you want to use the truck for. The handhelds have to make everbody happy so they go in the middle, a custom tune will set you up for what YOU want and also get rid of Torque Management which really hurts you at WOT.
As for the warranty, they have to prove that the mods you have done caused whatever problem you may have. So intake and exhaust changes are safe and as for the PCM they cannont tell you have done anything to it, the only way they will know is if you tell them. I cannot vouch for all programers out there but our tunes are dyno tested and mileage proven safe. |
| All times are GMT -5. The time now is 10:12 AM. |
