Help- Adding 110V Plug in lower dash
2022 110V plug has no power (front by cig lights)...
I added the plug today (purchased at dealer) but i guess I'll need some additional fuses or circuit breakers. Can someone please let me know which fuse(s) they are...
It sounds like you may need to add a fuse for the 110V plug to work. Check your owner’s manual for a fuse diagram to see if there is a specific fuse for the power outlet. Often, these outlets are on the same circuit as other accessories like the cigarette lighter. If the fuse is missing or blown, you’ll need to install the correct fuse size. If you can’t find the information in the manual, try asking your dealer for the right fuse number, or look under the fuse panel cover for a label with fuse locations. Make sure to use the right fuse to avoid damaging the circuit.
