Report Concerns, Make Suggestions, & Get Help Using The Forum A.K.A. Feedback Section Have questions, comments, or concerns about the website, post them here! NO TECH POSTS
Tailgate not opening
Old May 17, 2011 | 06:48 PM
Iceman777's Avatar
Default Tailgate not opening
I have a 95 GMC K1500 and the tailgate will not open. What do I need to replace?
Thanks for any help
Old May 17, 2011 | 06:51 PM
Most of the time it is just the handle. If you remove the bezel around the handle you will see a metal arm with a 90 degree bend coming from both sides. Sometimes a little lube will get it working. You can squeeze those 2 arms together to open the tailgate.
Old May 18, 2011 | 04:24 PM
Iceman777's Avatar
Yeah I have taken the bezel off before. Each cable gets pulled, but the left side gets pulled more than the right?
Old May 18, 2011 | 07:25 PM
You need a new handle, but you can take the handle out and try bending the tabs that pushes down on the part that the 2 arms attach to. Your right one is up further than the left one. This has only worked a couple times for me (I have repaired and replaced many). The handles are cheap so I would probably go that route and call it done.
Old May 19, 2011 | 05:37 PM
Iceman777's Avatar
Ok thanks
dannybriggs
Jul 20, 2013 08:05 PM
bsa_bob
Automotive Parts Wanted
Sep 28, 2010 02:10 PM
STRAYDOG
Feb 3, 2008 03:15 PM
06ado
Jul 26, 2006 04:14 PM
huntintruck
May 25, 2006 01:50 PM
