05 Sierra 2500hd CV Joint replacement
Old Dec 27, 2011 | 08:27 PM
Elvisdogbreath's Avatar
Default 05 Sierra 2500hd CV Joint replacement
Has any of you ever swapped out a CV joint(or drive axel)? I have to do this but was told that I would have to pull apart the ball joint.Does anyone who has done this know if that is true or can you just swap the cv joint? Any help would be appreciated? Cheers Elvis
Old Dec 28, 2011 | 03:02 PM
NullHead's Avatar
Have done it many times on small cars, but never on a truck. I usually disconnect the strut from the knuckle, but more than likely, you will have to disconnect the lower ball joint.
I just looked in the service info, and GM seems to think that you can do it by getting the axle out through the hole in the lower control arm.
They say it goes like so:
Loosen axle nut, loosen flange bolts, press the axle out of the knuckle, and push the axle down through the lower control arm hole.
Installation is reverse of removal, but tighten the flange bolts to 58 ftlbs, and the axle nut to 177 ftlbs.
Old Jan 7, 2012 | 10:54 AM
Nullhead I did the job and was super easy.Just take out the stabilizer link end for clearance and slide the cv thru it.Now I have to changew the hub assembly which I am doing today.That I think is going to be more difficult but I have a manual and will take my time.Those hub assenblies are sure expensive.I went with the SKF brand bearings not offshore.Thx for your info
skatafrata
Jun 30, 2011 11:13 AM
uscghalle
May 9, 2008 05:48 PM
majordad
Oct 18, 2007 10:05 AM
snowis
Sep 4, 2007 12:25 PM
scdeerhunter
Mar 17, 2006 09:45 PM
