cold air intake
Old Jul 18, 2011 | 04:00 PM
walleyejack's Avatar
Default cold air intake
am looking for a cold air intake system for my 2010 Silverado,5.3 any ideas on a good one,
Thanks al
Old Nov 27, 2011 | 01:29 PM
UH60HAWK's Avatar
Default Cai
I to am looking for a CAI for my 2010 6.2L. In my research i am finding that Volant is the way to go. Volant is the only CAI that has performed document R&D on Chevy truck engines. Not that this makes it the best but atleast somebody is doing there homework before throwing MODS after an engine. I have not installed one yet so i am merely describing the research i have done. I will purchase a Volant when i do go with a CAI. Good luck.
Old Jan 19, 2012 | 03:09 AM
02Z71CP's Avatar
hey guys a while back i bolted on a CAI myself was going to go with a K&N but i went with the next best thing. I got the Spectre intake from autozone it was like 140 bucks not too bad and i have it on a 5.3. Over all i ended up gaining around 12hp 13tq and 2.2mpg if you ask me its a good buy... Hope this helps
Old Apr 1, 2012 | 07:59 PM
SweeperForce's Avatar
I have the same one on my 2004 5.3l. Works flawlessly plus you got to love that intake sound.
Old Apr 13, 2012 | 11:32 AM
cycleman's Avatar
Default Cai
After reading posts I figured I would look into CAI. I have a 2010 Silverado K-1500. I thought $140 not bad BUT when I looked for my engine 5.3L SFI Spectre has price of about $420. Quite a difference. Guess engines have changed a lot in last couple of years.
Old Apr 13, 2012 | 12:37 PM
Ice_at_heart's Avatar
Piece your own together from a local autoparts store. They should be able to order the tubing and couplers.
If not find a metals depo and they should have aluminum in different shapes and sizes, you can order silicon couplers online cheap.
Old Apr 13, 2012 | 09:23 PM
rmck490's Avatar
I read that the CAI doesn't do much for power gains, but I'll agree that the sound difference is awesome. You don't need to buy an after-market package; K&N, Spectre, or Volant; to gain anything. You can piece the system together like Ice_at_heart suggests. Removing the stock tubing and the stock filter system are the key.
Some posters suggest keeping the stock filter box and using the filter of individual choice. Remove the stock baffling system and replace it with a direct intake tubing system. Depending on the stock configuration, sensor locations may come in to play. You will need to take this in to consideration when creating you custom CAI system.
Old Apr 16, 2012 | 09:25 AM
Highly doubtful, do you have a before/after dyno sheet?
Old Oct 29, 2012 | 03:28 AM
cycleman's Avatar
Default cold air intake and engine light
I put on the cold air intake from Spectre. Drove a couple hundred miles and the engine light came on. Took it to garage and he sprayed cleaner on the air intake sensor. Now driven it another couple hundred miles and the engine light came on again. Is this a problem when you put on a CAI?
DrmChld
Dec 7, 2010 08:17 PM
bigred29067
53
May 3, 2007 01:58 PM
holt16
May 2, 2007 12:09 AM
Makaveli187
Apr 30, 2006 10:00 PM
Makaveli187
Feb 25, 2006 08:58 PM
