Toyota Tundra Discuss the Toyota Tundra here.
88 toyota p/u
Old Oct 21, 2006 | 01:49 PM
kdub's Avatar
Default 88 toyota p/u
hi there i own a 1988 toyota p/u v6 when i am at idle my heat cools down .when i speed up it heats up again.. could someone help me here i cant figure this one out...Also when i first start the truck in the morning it runs ruff for 5 seconds then idles fine?? thank u
Old Oct 26, 2006 | 02:26 AM
toyota4by's Avatar
Default RE: 88 toyota p/u
there are a few things that you should check, first, your fan. second your thermostat, make sure it is the correct degree that toyta recomends, and finally you need to check your radiator cap to ensure pressure is being held in the cooling system. check all hoses and all clamps, also make sure that your not clowng white smoke when you rev it up, this is a sign of a blow head gastket which the six cylinders are nitorious for.
cbileske
Jul 28, 2011 01:24 PM
haschen
May 19, 2006 03:34 PM
biglpstacy
May 19, 2006 03:28 PM
cbileske
May 19, 2006 03:26 PM
ZX6STUNT
Vehicles for Sale
Sep 19, 2005 01:03 AM
