cracked frame
Old 04-16-2004, 06:25 PM
ejw78's Avatar
Default cracked frame
I have an 85 GMC Sierra 1/2 ton with some cracks in the frame. I noticed them because I was having trouble turning and when I inspected the steering box I notice that it had torn part of the frame away with it. There are also two small cracks on the top of the frame just behind the engine. Can anyone help me with advice on how to fix these cracks? I was told that just welding the cracks will not resolve the problem and they will only crack again.
Old 04-22-2004, 02:50 AM
Buy a new truck.
Old 05-13-2006, 05:51 AM
Default RE: cracked frame
you could try welding the cracks then grinding them down and welding a plat over the welded crack to strengthen it. And as far as the steering box side of things, I would do the same but pre drill it for the mounting holes, then bolt the box back on to the nwe plate
Old 05-13-2006, 06:30 PM
ORIGINAL: Divergent
Buy a new truck.
x2
Old 05-26-2006, 01:57 AM
yes you can weld everything up nicely, But you need to check to see if the frame is straight. If there are cracks then something is bent. That truck has had something major damage to it to rip the steering box up. I would just get a new truck.
Dangerous
05-24-2010 09:27 AM
bigkidfromlittletown
06-29-2009 06:13 PM
Leet413
05-02-2009 03:53 PM
slingersvt
12-01-2006 12:57 AM
xcrossroad
08-13-2006 07:33 AM
Quick Reply: cracked frame
