Need help, I want to add some HP
Old 05-02-2010, 07:22 PM
Bagged01's Avatar
Default Need help, I want to add some HP
Whats up guys, this is my first post and all i want to say is glad to be on here.
so lets get into it, I have a 2001 Silverado 4.8l reg cab.
What i want is to add alot of Hp without doing a motor swap.
I was thinking supercharger, and alot of upgrades such as intake, headers, intake manifold, camshaft, and everything else.
I heard that the camshaft and intake mani from a ls2 will fit on my motor without any modifications.
Im kinda new when it comes to motors but i do alot of suspension work and body work. so help me out guys what should i get.
Old 05-03-2010, 03:55 PM
timber74wolf's Avatar
Start with the basics. CAI, Tune, Exhaust, Cam, tehn upgrade to a supercharger or turbo. Just my 2 cents.
Old 05-03-2010, 05:16 PM
Worf's Avatar
It depends on how much you want to spend. You can go with the basics as stated above.
Afterwards you can add
Better heads,
Better Intake Manifold
Headers
Upgraded Ignition System,
underdrive pully kit,
better valves,
better crankshaft
if you have a manual fan, remove it and replace with a electric fan on the radiator,
you can have the engine ported.
And to answer your original question I have always liked superchargers over turbo, this is due to the lag that comes with turbos. There is a slight lag on a turbo at the begining until it gets going. There is no lag with a supercharger.
Old 05-04-2010, 01:28 AM
Bagged01's Avatar
thanks guys,
here is what i have planned
cam and intake manifold from a ls2
headers
CAI
ignition
and if i have the extra cash i might go get a supercharger
Old 05-04-2010, 02:40 AM
Worf's Avatar
if you do that you should also upgrade your ignition system
Old 05-04-2010, 02:44 AM
Bagged01's Avatar
i plan on running msd ignition and a new high output alternator and doing a big three upgrade,
Old 05-05-2010, 10:17 AM
HarderThanRocks's Avatar
Your right you will get lag from a turbo if you just go out and buy the first turbo you see on the shelf... If you do your homework and do things right the lag will be very minimal and will rob less HP (than a SC) from your engine to turn it..
Supercharger: good gains - HP lost to turn pully - added stress = good option for most people who want to plug and play...
Turbo: impressive gains - minimum hp lost to spool turbo - less stress than supercharger - major tuning required = best option for people who are able to put the time for the homework and is able to install himself..
smokinrx-7
04-29-2009 01:56 PM
Truck Cars
07-24-2008 08:40 AM
dijlop
02-18-2007 08:24 PM
dijlop
02-18-2007 07:57 PM
fndngemo
11-20-2006 11:20 AM
Quick Reply: Need help, I want to add some HP
