Dodge/ Ram General Tech Dodge tech talk within.
ABS/Speed Sensor Brake light on
Old 07-12-2004, 02:15 PM
jds313's Avatar
Default ABS/Speed Sensor Brake light on
<UL>
<LI><FONT face="Arial, Helvetica, sans-serif" size=2>1999 dodge ram 5.2 liter </FONT></LI>
<LI><FONT face=Arial size=2>lost my speedometer not working</FONT></LI>
<LI><FONT face=Arial size=2>ABS light on</FONT></LI>
<LI><FONT face=Arial size=2>no Cruise</FONT></LI>
<LI><FONT face=Arial size=2>Brake light on</FONT></LI>
<LI><FONT face=Arial size=2>So what is the problem</FONT></LI>
<LI><FONT face=Arial size=2>74.358 miles</FONT></LI>
<LI><FONT face=Arial size=2>David</FONT></LI>
<LI><IMG src=smileys/smiley6.gif border="0"></LI>[/list]
Old 06-05-2005, 01:31 AM
Default RE: ABS/Speed Sensor Brake light on
first thing check all fuses. after that you might be looking at a bad wheel sensor, that would cause the lights,
Old 10-16-2005, 06:49 PM
Same thing happened on my Dak.Not sure if they are the same though,but when it happened to the Dak my rear abs speed sensor had went bad.It is located on the rear end housing.
Old 10-17-2005, 02:22 PM
Patrick's Avatar
i worked for dodge for a while, and we replaced alot of these. also, did the ABS light come on at the same time that the speedo quit working? the two possibly could be unrelated.
05chevytruckguy
02-15-2012 09:58 PM
GMCSierraFan
04-25-2011 04:38 PM
brooke01
01-04-2007 08:43 PM
ral3ph
04-29-2005 06:12 PM
84DustemDlux
04-22-2004 02:32 AM
Quick Reply: ABS/Speed Sensor Brake light on
