No heat 97 F250 HD, gas
Old 10-14-2015, 01:22 PM
tikaani's Avatar
Default No heat 97 F250 HD, gas
I have been trying to track a lack of heat in my 1997 F250HD with the 7.5 L gas engine. I have replaced the thermostat and get "normal" heat readings. Both hoses to the heater core are hot. I looked at the end of the cable attached the heater dial and the external components move. There is a vacuum actuated valve in the engine compartment. It activates when I start the vehicle.
Any ideas? Thanks. And I did search the forum, but might not have used the right key words.
Old 04-27-2019, 06:18 AM
Murphy777's Avatar
is the heater core clogged?...I believe on those trucks the heater core is located behind the glove box....also make sure your antifreeze levels are good. My 97 f350 diesel was running a little hot and I was getting no heat....it turned out to be about 3 gallons low on antifreeze.... now the truck is cool and the heat is working again...where the antifreeze went is my bigger problem..hahah
raddroxx
12-26-2012 08:24 AM
Roush08
11-19-2008 05:45 PM
jcbst12
05-14-2008 08:36 AM
Carter56
12-13-2007 09:35 PM
shampboys
08-20-2006 06:12 PM
Quick Reply: No heat 97 F250 HD, gas
