Chevy/GMC Heavy Duty Discuss your 2500 and 3500 Chevy and GMC pickups as well as the DURAMAX diesel and it's predecessors
O4 2500 silverado motor swap
Old Aug 10, 2017 | 09:50 PM
switzerfarm's Avatar
Default O4 2500 silverado motor swap
Put a complete lq4 drop out motor in my silverado 2500 hd 6.0. I used the original pcm but the complete wire harness that came with the dropout. Now pulling 3 trouble codes. Po300 random misfire, po650 warming light open circuit po717 no signal from turbine output input sensor. My feelings is this is a pcm problem I changed the output sensor, no change no signal or amperes on wire, the misfire I changed the whole coil assembly on both sides no change. My code scanner is in for repair with snap on. Need some help
Old Aug 14, 2017 | 09:00 PM
Default Figger it out
po717 code was because I didn't get the input sensor connector pushed all the way together. The po 300 was # 8 spark plug wire was a little off and not pushed all the way on. All code gone. Lesson learned. Don't get in a hurry and overlook small things
DBWRSV
Feb 15, 2012 01:45 PM
donparadowski
Sep 5, 2009 01:03 PM
evolancer839
Mar 28, 2009 08:36 AM
psyclone
Mar 14, 2009 04:16 AM
94 dodge ram 2500
Aug 5, 2006 05:08 AM
