hey doin a motor swap got a ?
Old Mar 22, 2009 | 07:49 PM
evolancer839's Avatar
Default hey doin a motor swap got a ?
Hey i have an 02 silverado 2wd with a 4.3. I wanna put a 350 in i was just wondering how doable is this? what will i need, run into, and what about inspection/emissions?
Old Mar 22, 2009 | 08:51 PM
Considering how they didn't put a 350 in that year. I am guessing itwould be somewhat difficult
Old Mar 22, 2009 | 10:44 PM
98white5.0's Avatar
I'm not sure about swapping to a 350 on that year. Since you already have a 350 with two cylinders lopped off, you would be able to do the swap. Not sure about the difficulty, probably in the 8 out of 10 range. You might want to just stick with a 5.3 though. IMO, it would probably still not be fun, but anything is possible as long as you have patience and money. I guess you could always go carbureted...they are not as hard as fuel injection when doing a swap, but who wants to do that? I say stick with a 5.3 on that particular year model.
You'll run into wiring harness, motor mounting, maybe transmission mating. Not sure if the transmission from a 4.3 will work on a 5.3, assuming you've changed your mind on the 350.
I think if you still wanted to do the 350, wiring harness will be the major problem, since the transmission will bolt straight on. Motor mounting will always be adjusted. I know I've forgot a few more details but someone else will probably chime in and help out.
Old Mar 22, 2009 | 11:31 PM
chrisbmo2000's Avatar
considering GM did not make a 350 in 02 the computer is worth less and unless you know a computer engineer a carberated engine is THE ONLY way you could go.....I agree with 98white5.0 a 5.3 will be ALOT simpler
Old Mar 23, 2009 | 07:56 PM
crawl daddy's Avatar
6.0!!!!!!!!!!!!!
Old Mar 23, 2009 | 09:05 PM
dmccartyfan's Avatar
Just an opinion - unless you've got real sentimental attachment to the truck w/4.3 (or you happen to have a built 350 sitting around collecting dust), might it make sense to trade up to a truck that's properly equipped? All the hard work has already been handled by Chevy. On that note, if you DO have a 350 ready to go, maybe pick up a truck that once HAD a 350 - transmission, suspension, driveshaft, etc. is already built for that size powerplant.
Seems like a tough project, that's all. Good luck and let us know how it goes!
Old Mar 28, 2009 | 08:36 AM
restridge's Avatar
An old carbureted 350, 373, 400 would be much less work & much more fun. There would be some mounting work to do, but much less computer/harness work. Or you could probably find an S10 or Ranger with a small block already in it cheaper than doing the swap in your truck.
gmcmannow
Apr 20, 2013 05:33 PM
b3no7
May 10, 2011 11:34 AM
Axeman
Apr 6, 2011 01:30 PM
Hollonator
Mar 8, 2010 02:00 AM
Alucardus
May 27, 2008 09:38 AM
