1990 5.7 misses when accelerating
Old Oct 11, 2006 | 06:39 PM
sclaymore's Avatar
Default 1990 5.7 misses when accelerating
I have a 1990 K1500 with a 5.7 liter engine and automatic trans. At speeds above 35 mph it misses significantly while accelerating with medium or light pressure on the throttle. If I floor it it vanishes. I have changed out the spark plugs, cap, rotor, and both electronic components in the distributor. The timing is right on. The miss seems to be much less pronounced when the engine is cold and gets worse as it warms up. what's going on?
Old Oct 15, 2006 | 02:08 AM
JDinNewYork's Avatar
Default RE: 1990 5.7 misses when accelerating
What I would try next is in the evening when it's dark, have someone accelerate your engine at about the PRM that the missfiring problem is the worst and look for the plug wires shorting out or arking. You'll have to undo any under hood light bulbs before the test. Be very carefull as well checking anything by hand during this test (fan, spinning belts, good jolt from a bad plug wire, accidents happen) best to have a flashlight handy. Good luck.
lebanontn
Sep 7, 2009 11:23 AM
ranger99
Sep 20, 2008 09:25 AM
64lover
Dec 14, 2007 04:23 AM
64lover
Nov 26, 2007 07:53 AM
jm7777
Jul 26, 2007 05:53 PM
