1995 Chevy new motor problem...
Old Aug 10, 2011 | 07:58 PM
  #11
2oCHEVYo0's Avatar
The injectors are still the same ones from before the swap. Could a loose throttle cable make it run like that? I told my friend that I thought that might be the problem but he looked at me like I was stupid.
Old Aug 10, 2011 | 08:53 PM
  #12
cubpak89's Avatar
well i do know that it will cause funny things to happen most people will look at ya like your crazy when ya ask as that is a very rare problem anymore but it does happen especially when swapingmotors
Old Aug 10, 2011 | 09:26 PM
  #13
MrDragon's Avatar
I'm still thinking fuel delivery issue simply because of the response problem you're having. I wonder if flashing the computer might help in case there's a sensor that's different. Flashing the pcm will allow it to recognize it and run default settings.
Old Aug 11, 2011 | 01:08 AM
  #14
2oCHEVYo0's Avatar
I was thinking of flashing the computer. How would I go about doing that exactly? The battery was disconnected for a couple days and thought that would have caused it to reset but maybe not.
Old Aug 11, 2011 | 07:08 AM
  #15
Does it ever clear up after bogging? My 1992 would bog pretty bad when taking off then it would clear up and go. I have a 95 also so one day I started swapping sensors to see if I could figure it out. None of the sensors made a difference so I took a vacuum cap and blocked off where the EGR solenoid attaches to the throttle body. It ran like a champ and since I had already tried replacing the solenoid with a known good one I figured I either had a bad EGR or the wiring was messed up going to the solenoid. I swapped EGR's and it cleared right up. The weird thing is with both EGR valves on the bench they both tested good with a vacuum test. Good luck!
Old Aug 11, 2011 | 07:35 AM
  #16
MrDragon's Avatar
@Shamrock. That's a great idea, I didn't think about bypassing the EGR
Old Aug 13, 2011 | 10:42 AM
  #17
acnas's Avatar
When you set timing was the wire under the heater box disconnected?
Old Aug 13, 2011 | 01:27 PM
  #18
2oCHEVYo0's Avatar
I did dissconnect the wire under the heater box when I timed it. The bogging does seam to clear up when driving as I had no noticeable problems when driving to my house a month or so ago. I am going to order an EGR delete kit and see if that will help me out at all.
Old Aug 13, 2011 | 09:23 PM
  #19
Before you do that just cap off the port on the TB and take it for a ride.
Old Aug 22, 2011 | 07:38 PM
  #20
2oCHEVYo0's Avatar
Well I finally got some free time to mess with the motor today and have some VERY GOOD NEWS (I hope)! I disconnected the EGR valve and started it up and messed with the throttle for a good 5 minutes with no issues. Then I hooked the EGR back up and it started having the same issues again (bogging and a slightly rough idle) so I unplugged it just to make sure and it was running fine again. Haven't taken it out on a drive yet since I still haven't welded the exhaust back up from the motor swap so it's still kind of loud but I will keep you all updated! Thank you for your input guys, it may have taken a little while but I feel we have finally solved the problem here!!!
GREEN305
Vehicles for Sale
Jun 4, 2012 03:10 PM
josh29j
Oct 21, 2009 04:29 PM
donparadowski
Sep 5, 2009 01:03 PM
captts22
Jan 19, 2009 02:47 AM
95Crateboy
Vehicles for Sale
Nov 14, 2006 02:06 AM
