1998 K1500 Vortec starts but won't run -- help!
Old Mar 21, 2018 | 09:15 PM
  #21
Samantha Gremillion Mathison's Avatar
Originally Posted by Justin Holtsclaw Hsc
Has anyone found a solution to this issue? My only difference is I parked my truck for loss of oil pressure even after new pump and oil sender switch. I went ahead and completey rebuilt this engine with all new internals, crank turned and head work done. I put it all back together and have checked my connections and grounds many times. I' getting great spark and fuel. But like above it's like the pump don' kick back from first fire. Have tried the security pass ock relearn a few times. My only difference is when I turn my key on, all my lights dont display, and only 4 do after it dies. I' gonna try to do the pass lock bypass today and see if any change, if not I'm gonna do as OP said and jump the fuel pump wire to a switched hot. But cant' it be done at the fp relay?
My husband's was a loose wire in the steering column. Have you changed your ignition switch/ wiring harness? Many issues with this stem from the steering column. If you've done everything else, focus your attention there.
Seriously, 1 month working on it and thousands of dollars later, a toothpick fixed the problem...
Old Apr 14, 2020 | 08:14 AM
  #22
Pecosbill7's Avatar
So what ever happened on this thread? Did you figure out what it was?
Old Apr 29, 2022 | 07:20 AM
  #23
lilstein3's Avatar
Can u please tell what the problem was?
Old Jul 18, 2022 | 07:54 AM
  #24
Pecosbill7's Avatar
Hey, it’s not nice to leave folks hanging like this! Did you ever figure out what was wrong?
dkrood
Apr 1, 2018 03:43 PM
louisianaoutlaw
Apr 19, 2014 08:50 PM
Old Wrench
Apr 1, 2014 10:33 PM
webrik33
May 14, 2008 04:56 AM
general z
Aug 1, 2006 05:58 PM
