2 issues both with heating
Old Dec 9, 2011 | 01:29 PM
gmc newbie's Avatar
Default 2 issues both with heating
Hi everyone!!!
Ok, I have a 95 Sierra, a little rough around the edges, but runs well and I love the old girl. There are 2 issues I am having:
1) Mt temperature gauge has decided to crap out on me. I have checked the male end of the plug and the wiring as far up as I can, and haven't found a break anywheres. The needle is sitting on the left side Of the gauge, which is leading me to believe that the temp sensor has gone kaput on me. I am only saying this because I had a previous one that had a break in the wire, and it was showing max temp. Please advise.
and;
2) I only get the blower motor to work in the cab when I place it on high, it won't work on any other setting. I have talked with several people, and they are leading me towards the blower motor resistor. Not sure if this is true or not, but I can't find a mention of it in the Haynes book at all, so not really sure what I am looking for. If anyone can lead me in the right direction for either issue I would appreciate it.
Thanks everyone!!!
Old Dec 9, 2011 | 06:54 PM
1) Ground the wire and see if the gauge moves if so it is your sensor.
2) Yes it is the blower resistor - remove your glove box and you will see a plug going to the resistor and 2 screws holding it in. It screws right into the air plenum. It is a common problem, but an easy fix.
Good Luck!
Old Dec 10, 2011 | 10:57 AM
gmc newbie's Avatar
OMG!!!!!
Got the resistor in....... whoever designed it must of had hands no bigger than a little girl's, cause I had a hell of a time trying to get the part in and out. !!! Still working on the temp sensor....................
Old Dec 10, 2011 | 08:35 PM
Yeah it's tight and usually GM puts a couple of razor sharp pieces of metal or plastic near by so you can leave a little DNA behind.
Old Dec 10, 2011 | 11:28 PM
NullHead's Avatar
My dad's '97 has the same issue with the dead spots in the fan speed. Great thread! I'll have to see if I can't get a resistor pack in there one of these days.
firefighter148
Aug 5, 2010 12:44 PM
badbowtie
Jan 9, 2010 07:26 PM
Shane31794
Nov 17, 2009 08:12 PM
NewOne
Aug 16, 2009 02:39 PM
ford4ever
Ford Concepts & Rumors
Oct 3, 2007 08:49 AM
