2 problems with a 2003 Sierra 4x4
Old Apr 16, 2008 | 03:29 PM
Cubsfan13's Avatar
Default 2 problems with a 2003 Sierra 4x4
Hi, first time on this site. I have a 2003 Sierra 4x4 with 2 separate problems. I believe I may have found an answer to my first question on this site but I wanted to make sure. When I make turns at a low speed I hear a rubbing sound. Not sure if this is the same problem everyone else keeps reporting on steering problems with their Sierra's?
Second question when I start my truck after it has sat for 2 or 3 hours it is hard to start. I do have a remote start unit on the truck not sure if that could be the cause of it being hard to start?
Old Apr 16, 2008 | 07:05 PM
Argon's Avatar
Default RE: 2 problems with a 2003 Sierra 4x4
hard to start...does it spin?...just takes a bit to actually run?...or is it spinning over slow?
the steering clunk....with the wheel slightly turned,going slow over some bumps..it will be felt more than heard...bump-clunk type feeling
Old Apr 17, 2008 | 12:14 PM
Cubsfan13's Avatar
When I crank it over it will spin until it starts or if I let off the key and crank it again it will almost always start immediately.
As far as the steering problem I will try what you are saying and see what I experience.
Old Apr 17, 2008 | 06:34 PM
Argon's Avatar
on the starting...look on the left side of the engine...a small metal pot with a vacuum line...its the fuel regulator...pull that line off and see if its gassy....the reg could be dripping gas into the vacuum and flooding....you may have to check it a few days in a row
tyhatts
Apr 13, 2012 09:16 AM
Elvisdogbreath
May 15, 2011 11:58 AM
Brian Webb
Aug 17, 2009 10:03 AM
carl777
Jan 25, 2009 10:07 PM
1997 chevy
Oct 6, 2008 11:25 PM
