2001 GMC 8.1L keeps quitting!
Old Apr 26, 2012 | 01:24 PM
Shuckles's Avatar
Default 2001 GMC 8.1L keeps quitting!
My father in laws 2001 gmc 1 ton crew dually with 8.1L randomly quits. There is no check engine light on, it doesn't sputter or anything like that it just seems like someone shuts it off. It will start back up after few seconds if not right away and then it could be fine for days before it randomly shuts down again. The truck has just under 160,000kms and is serviced regularly. It runs the same as when new has tons of power and is actually decent on fuel. Any suggestions?
Old Apr 26, 2012 | 02:22 PM
My truck was doing that and it was the double positive going to the battery. It has a long bolt and there is a lead spacer between the 2 terminals. The lead shrinks from years of tightening and will cause a bad connection. I am not sure if the newer trucks have this same set-up (mine is a 98), but it was as simple as putting a small washer in there to take up the slack. You can also buy a new bolt and spacer from the auto parts store, but I had the perfect size washer in my collection and it has been working for months without a problem that way.
Besides that it could be an ignition switch issue. Good luck!
JFoster
14
Jul 12, 2011 09:24 AM
big al51
Nov 19, 2008 09:27 AM
MRC Chevy
8
Aug 26, 2007 10:11 AM
1BadBird
May 13, 2007 03:10 PM
steelfan
Dec 8, 2006 05:20 PM
