2004 overheating
Old Jan 22, 2009 | 02:43 PM
pricingbabe's Avatar
Default 2004 overheating
My truck keeps overheating although I can't see any anti freeze leaking out of it. Could the thermostat be stuck?
Old Jan 22, 2009 | 06:54 PM
timber74wolf's Avatar
Default RE: 2004 overheating
What is your temperature gauge reading? Do you have enough coolant in it? Is your fan turning properly or is it turning slowly? If it is turning slowlythe fan clutch could be bad. Do you smell antifreezewhen the truck is at proper operating temperature?Have some one pressure test the system is another thing you could have done. Look at all the simple stuff first to narrow down what it cold be.
Old Jan 25, 2009 | 01:16 PM
Yes, there is enough coolant. It overheats almost immediately, up to 210 (before I shut it off.) Where is the thermostat, anyway? Looked at it quickly yesterday, but it was about 15 deg out so didn't linger, and couldn't even find the thermostat to check it. Will check out the fan. Can't smell antifreeze.
Old Jan 25, 2009 | 08:04 PM
DamnYankee's Avatar
210 is normal operating temperature.
Old Jan 25, 2009 | 11:08 PM
Steven's Avatar
my friend had that prob on his s10 after we changed the water pump and it was just a air pocket in the line did u change ur water pump or run it out of fluid lately
Old Jan 26, 2009 | 09:15 AM
DamnYankee's Avatar
again...210 isn't overheating...
rpmc
Feb 22, 2008 08:53 AM
drzoid
Feb 5, 2008 08:58 PM
Mazrolet
May 14, 2007 08:14 PM
plow guy
Feb 20, 2007 11:07 AM
mower
Aug 12, 2006 02:39 AM
