2005 GMC Sierra 1500 Starting Problems
I have a 05 GMC Sierra 1500 with some starting problems. It only happens occasionally and is random it seems. When I try to turn the key nothing happens with the starter only thing that I can hear working is the fuel pump. The radio works ac and heater work just when I try starting it will not start or turn over. After I try it for a while it will finally start but it never has the same pattern. Doesn't matter if its a cold start or warmed up. I'm just not sure what to do about it. Any help/suggestions is appreciated.
I have a 2000 sierra 1500 that does the same thing. when it happens does your security light come on at the message center, if so go to the owners manual and follow the steps to deactivate the security system then re activate it . I did this and its not happened since. If your owners manual doesn't have it just let me know and i walk you though it.
Ok try this :
This worked for me so i hope it works for you.
- open the driver side door.
- lock the door with the remote. Look inside the security light should be on .
- close the door and the light should go off in 15 or 20 sec.
Bad Igntion Switch: If your battery checks out, but the starter is still silent, it may be a faulty ignition switch. Turn the key to the on position (not all the way to start). If the red warning lights on your dash don't light up (and your battery connections are clean), the ignition switch is bad. If they do light up, turn the key to the start position. The dash warning lights should turn off at this key position (most cars). If you're not sure, turn on the headlights. When you try to start the car, the lights should either dim (a lot) or turn off completely. If they do, your ignition switch should be ok. If not, the switch will need replacement.
Bad Starter Connection: Corrosion can not only keep your battery from connecting, it can affect any electrical component, especially the ones exposed to the elements like the starter. If you have a helper, you can test the connection by holding a circuit tester lead on the wire that engages the starter. This is the smaller of the two wires connected to the starter. Be sure no part of your body is near the moving parts of the engine - it could still start at any time! Have a friend turn the key and check the current. If you're getting current to the starter but it ain't spinning, it needs replacement.
If your starter spins freely when you turn the key, the problem lies elsewhere
Fynx
Sep 28, 2014 11:41 AM
bpa1216
Jan 25, 2010 05:34 AM
