2nd Battery
Old Jan 31, 2008 | 04:30 PM
97 Black Z71's Avatar
Default 2nd Battery
Anyone have any links or ideas on how to properly add a second battery to a 97 Z71? When I turn on my 5 KC spots on the roll bar my voltage meter goes flat.
Thanks in advance.
Tommy
Old Jan 31, 2008 | 04:34 PM
rxsteven's Avatar
Default RE: 2nd Battery
You might have to get a alternator that puts out more.
Old Jan 31, 2008 | 05:23 PM
chevyrules's Avatar
Thats where i would start, with a larger output alternator. I know many years ago, me and my buddys used to run Warn 8,000 Lb winches on our Jeep CJ's, as well as 3-5 KC Hiliters, it put a strain on our batteries. I believe we replaced stock alternator with higher output ones, and also put in bigger batteries. Never did 2 batteries tho, but wanted to.
Old Feb 1, 2008 | 09:23 AM
jcbst12's Avatar
A higher output alternator will work. Try a Optima Yellow top battery before you do two batteries. Yellow tops have a high reserve capacity, like a maqrine battery would, only with more cold cranking amps.
Old Feb 1, 2008 | 09:56 AM
gpet6669's Avatar
It also helps to have the second batt to draw off of. It helped to keep my voltage from spikes and dropes, which keeps the electronics from getting messed up.
MightyMike
Aug 6, 2012 01:52 AM
jkw_gmc
Jul 30, 2009 12:31 AM
thomasnchy
May 7, 2009 08:11 PM
Achase
Jan 2, 2009 04:49 PM
sknaffl
18
Dec 3, 2007 03:54 PM
