89 1500 rebuild.....
alright here goes... im 17 and this is my first truck.
I got it for $500 so obviously im on a budget i want a good truck thats kindof affordable and need some help.
its got a 350 with a mild cam and a 700r4 automatic transmission. the transmission sticks in first gear and has some problems going into second, what should i do get a new one or rebuild my current one? any other ideas would greatly be appreciated.
talk to a tranny shop. see how much theyd charge for a rebuild and at the same time look into the junk yards and look for any usuable 700R4s now remember you can use any 700R4 even out of those crappy astros. then play the price game of which ever one is more in your budget.
thats some great advice. well on another note...being a teenager i want to have a good lookin truck that i can hold onto. its got the 350 so any ideas on motor work? right now the only thing i put on the truck was wheels n tires. i went with another GM wheel i went with a 16 in late 90's model without the centers, what size tire should i go with? also any ideas on what i should do with thee old wheels and tires?
so you have new stock Gm 16in? then go with a set of 245/75/16s seeing as those were the factory tires put on those 16in rims. in fact i have that set up on mine and they look really good.
as far as the motor build. how many miles are on the motor. and what year is the motor? depending on the year you will have some different mods you can use.
right now im not sure i just work a part time job and work until i can get the money to replace what needs it. also the oil pressure gauge is faulty and the truck will start to die and ill have to pump the gas to keep it going is that due to the electrics or does it need motor work? or do you have no clue?
