93 1500 won't start when warm
Old Aug 4, 2010 | 10:20 PM
spidyrmen's Avatar
Default 93 1500 won't start when warm
I have a 93 1500, 4x4, 350, automatic transmission. The truck starts just fine when it the engine is cold, but after it reaches normal operating temp and I shut it off, it acts like the battery is dead. I had the battery, alternator and starter checked and they are fine. It will start if jumped. The battery has 700 cranking amps. I have checked the ground and have cleaned the cables. It has a new starter and solenoid. I am at a loss. Any help would be greatly appreciated. Thank you in advance
Old Aug 5, 2010 | 12:07 AM
RUFFNECK4LYFE's Avatar
That sounds like a bad or weak ground cable somewhere. The PCM might have one on those, might check for that.
Old Aug 14, 2010 | 06:10 PM
farmboy91's Avatar
I had this happen to me aswell and after 3 starters i found that it was just a ground cable
Old Aug 14, 2010 | 08:32 PM
timber74wolf's Avatar
Recheck your cables and see if you got a bad ground connection. Also when is the last time you did a full tune up meaning: plugs, wires and the cap and rotor? Might want to check teh cap and rotor especailly and possibly a bad distributor. We had a distributor going bad on my mom's 89 Chevy Astor van. The distributor shaft had worn the bushing out allowing the shaft to wobble after it had heated up. Start with your cap and rotor see if it is corroded up.
Bmsmith82
Jan 31, 2011 12:44 PM
chevychick93
9
Jul 15, 2010 08:45 PM
jackedupride
12
Apr 14, 2008 01:02 AM
rmriderz
Apr 26, 2006 11:32 AM
rmriderz
Mar 9, 2006 06:28 PM
