96, 350 fuel pump question...
Old May 3, 2008 | 08:10 PM
jagman454's Avatar
Default 96, 350 fuel pump question...
alright so I got a broken down 350 from some 90's chevy truck (not sure), but it is carburated, and I want to rebuild and swap this into a 86 Chevy truck, but the only main differences I notice with these engines are that the old one has a driven Fuel pump on the front right side of the block, and on the new 350 this is bolted off, when I switch engines can I just take of the plate from the new 350 and put on the pump from the old 350?
thanks alot!
-Mitchell
Old May 3, 2008 | 11:28 PM
6mins2live's Avatar
Default RE: 96, 350 fuel pump question...
Well I can not answer your question but I can tell you that if you motor is out of a 90's truck then it is not carburated. This is a common misconception because it has the look of one. What it is, is Throttle Body Injection. I dont know if this helps you at all but it should some because theyaredifferent engines so I would assume that your idea would not work. Could be wrong tho.
Old May 4, 2008 | 07:46 AM
jagman454's Avatar
Ok, that makes sense, but... if I change the intake/heads it would work tho right? I mean all 350 short blocks are the same reguardelss of fuel delivery type correct?
Old May 4, 2008 | 09:08 AM
Argon's Avatar
those TBI engines..or K motors...have a fuel pump hole with a plate over it as you have,or either its casted over.you can use it,just switch your rod and old plate over...if you use the heads,you'll either have to buy a custom fit intake,or get creative drilling your intake bolt holes out more,as they go in at different angles.
keep the flywheel starter paired together.
do-able,but ain't fun
Old May 4, 2008 | 08:33 PM
jagman454's Avatar
alright well, then I'll just use the block and swap over the fuel pump, and get new heads/intake really appriciate it!
-Mitchell
ecarri100
Jan 9, 2011 09:54 AM
chrisbmo2000
Dec 24, 2010 03:35 PM
needshave
Jan 24, 2010 12:53 PM
jrk99
Dec 7, 2009 11:57 PM
jagman454
May 3, 2008 08:09 PM
